Window sticking on weatherstriping
Posted: Fri Jan 13, 2006 5:15 am
by subawhatsubawho
My drivers side window seems to be catching the weatherstriping on the way down sometimes. IS ther anything I can do about this?
Posted: Fri Jan 13, 2006 6:36 pm
by Yukonart
Silicone lube?
Posted: Fri Jan 13, 2006 7:43 pm
by scottzg
armor all or vaseline
Vaseline kills wind noise better
Posted: Fri Jan 13, 2006 8:40 pm
by subawhatsubawho
Won't that leave streaks all over my window when I roll it down and up?
Posted: Fri Jan 13, 2006 9:00 pm
by 0perose
all four of mine "Freeze" shut if it goes below 20*F... I think this is related to the problem I have where the inside of the windows frost over because of condensation? still can't figure this one out, but I often find myself going 60mph down the road, with my door open, hitting the window switch, and pushing on the top of the window to get it to roll down so I can smoke a cigarette on my way to work
Posted: Sat Jan 14, 2006 4:08 am
The felt is probably worn away on the weather stripping. Mine was like that. I ended up getting a used piece at a junkyard. That top piece with the chrome strip and felt is held on by metal tabs. Just bend them up and you can slide the old one off, and put a new one on.
Posted: Sat Jan 14, 2006 5:18 am
by subawhatsubawho
Thats it Josh. Thanks for the advise.
