Supercharging 2.2 feasible?
_Aramchek_
Is it possible?,is it relatively inexpensive and easy?,is it going to be worth it?
subawhatsubawho
sammydafish
feasible? relatively inexpensive? those are quite objective terms. There's nothing you could think of doing to an EJ engine that hasn't already been done. If you're going to worry about feasibility and cost then you either shouldn't be doing it, or are quite handy with a welder and crazy enough to try anything. The later is most likely not the case or you probably wouldn't have fielded the question. Giving you the benefit of the doubt though, I turbocharged my wagon, all custom junk yard parts and still have less than a grand into it including buying the car. Not sure what Doug spent, but he kept the cost down since he seems to be a handy fabricator.
it's all relative
it's all relative
- Junior
95L Wagon on T3/T4 boost :)
