Boost issue, max 11psi
Posted: Tue Jan 17, 2006 3:10 am
by RallyRS
Hi,
I have a old school 1989 Legacy RS. I have got a heap of Eprom chips which tune the car differently.
I have 14psi, 17psi and 21psi chips. That is what written on the chip anyway, I didn't program them.
Anyway no matter what chip I put in the psi only over reaches 11psi (normally 10psi). If I flick the switch back to standard ecu, it runs about 6-7psi.
Why is it peaking at 11psi?
Is it a turbo problem? I have vf8 (wastegate spring tension???)
Is it a fuel cut problem?
Is it just badly tuned eprom chips?
Plumback BOV not holding pressure?
Many questions!
I hope someone may be able to help!
Cheers
Hayden
Posted: Wed Jan 18, 2006 4:38 am
by RallyRS
Someone please help!
Any crazy idea :)
I have given some examples of what I think might be wrong but Im not mechanic and have no idea! Just catch words I pick up.
Posted: Wed Jan 18, 2006 4:53 am
by dzx
unplug the wastegate and see if that changes anything. I'd definately watch the boost while doing it tho.
