my car wont start. not the normal problems
Posted: Wed Jan 18, 2006 7:55 pm
by azn2nr
ok so my car will not start. i have bad starter contacts and i know this but its not so bad that i cant get it started at least eventualy.
from what ive read i have a bad coolant temp sensor. this from the car turning over without starting unless i hold the gas.
today, well last night i parked outside for the first time in a long time and this morning the car wouldnt start. at first i thought bad starter contacts. but then it started to turn over verry slowly, about 4 seconds a turn. then faster and faster but never up to normal starter speeds. i heald it there until the speed sort of plateaued and let the key off. i could never get it to turn over again.
what is it this time
Posted: Wed Jan 18, 2006 8:00 pm
Are the battery terminals securely tightened?
Flat battery?
Posted: Wed Jan 18, 2006 8:13 pm
by azn2nr
terminals are secure. ive had that problem before and its deffinatly not that. flat battery is a maybe. this is the batterys second winter with me. and i dont know when the last time it was replaced as i bought the car used. yet then again. if it were to be a flat battery the starter wouldnt have speed up as it turned more adn more
Posted: Wed Jan 18, 2006 8:50 pm
It could... another way to describe what's happening is that the starter motor is accelerating very slowly and not reaching its full speed.
Posted: Wed Jan 18, 2006 8:54 pm
by azn2nr
thats actualy exactly how id describe it. and its not reaching full speed by a long shot. im gonna go grab a battery for giggles later
Posted: Wed Jan 18, 2006 8:58 pm
Well first just try measuring the voltage on your battery.
Maybe a jump-start will help things for now.
Posted: Wed Jan 18, 2006 9:02 pm
by skid542
My money is on the battery.
Posted: Thu Jan 19, 2006 12:17 am
by azn2nr
yup. i hooked it up to a 50 amp and it fired right up
Posted: Thu Jan 19, 2006 4:11 pm
You should change the title of this thread. :)
