EJ22T->EJ18 wiring Q's
Posted: Mon Jan 23, 2006 3:33 pm
OK, I've decided to try and run my EJ18 off of an EJ18 ECU (how 'bout that
). I grabbed an EJ18 throttle body, ECU, and ECU plugs, (quite literally), and already have the EJ18 TCU and plugs. What I want to know is, what all exactly needs to be done to get the thing to run properly, and throw no codes. I mean, is it even possible at this point? I've been running it with the EJ18, and the AWD 4EAT that was attached since '93, and that tranny doesn't seem to want to play nice with the Legacy TCU, and I'm running it off of a NA 2.2 ECU. I've been getting 17mpg since then. I know it's a heavy car but come on.
I have the ECU pinouts for the Legacy and Impreza, but will simply wiring up the TCU, ECU, and the proper IAC and TPS make everything play nice and not throw any codes?
