Will the rear sag with 04 STi struts and springs?
Posted: Tue Jan 24, 2006 4:04 am
by Drifting STi
I did a search and found nothin in specific to 1998 legacy wagon running 04 USDM Sti springs and struts.
Can awayone give me some advice b 4 I do all this work.
Posted: Tue Jan 24, 2006 8:25 pm
by DLC
It would help if you could find the spring rates for the STI. Chances are they're pretty high, so you won't have to worry much. Someone should compare the gross weight of a 98 Legacy wagon and an 04 STI...
Posted: Tue Jan 24, 2006 8:52 pm
by JasonGrahn
If you're going to install the springs and struts, also compare the bumpstops from either kit.
Posted: Wed Jan 25, 2006 12:28 am
by Drifting STi
Thanx for the tip guys..... I make sure to check the bump stops.....
Shorter is always better on the bump stops right?
Posted: Wed Jan 25, 2006 12:33 am
by JasonGrahn
I'd like to provide for you an emphatic "Hell no" as an answer to your question.
Posted: Wed Jan 25, 2006 2:55 am
by Drifting STi
lol "hell no" it is...
I just picked up the struts....STi Struts have internal bump stops.....So I cant do anything about that
Posted: Wed Jan 25, 2006 4:58 pm
by JasonGrahn
Ah, so the STi's are inverted. Good.
