WTB: fuel pump assembly
Posted: Thu Jan 26, 2006 12:02 am
by petridish38
Hey,
All I really need is the power supply to the fuel pump. It looks very similar to the one outlined in red except that it has two ring terminals on the end.
So all I need is the connector and the wires as one piece in good condition, but I will take the whole fuel pump assembly if i have to...
Andrew
Posted: Thu Jan 26, 2006 1:35 am
by Binford
I just threw mine away! I could probably dig it up out of the dumpster at work, though. What happened that you need one?
Posted: Thu Jan 26, 2006 2:08 am
by petridish38
Posted: Thu Jan 26, 2006 6:49 pm
by petridish38
Please guys! I need this part ASAP!
Andrew
Posted: Thu Jan 26, 2006 8:08 pm
by skid542
If you pay attention to your polarities you could just get some wire and connectors from walmart/radioshack/etc. and do a temporary wiring until you get the actual part that has the fancy connector.
Sorry it's not more helpful as in I don't have one but if you're in a jam you could do it temporarily.
Posted: Thu Jan 26, 2006 8:23 pm
by MPtyza
Is it one that is two wires, one black, and the other orangish red, with a thin beige connector? If so, I've got one that you can have for free.
Posted: Fri Jan 27, 2006 12:12 am
by petridish38
does it look like this mike?
http://www.thawa.net/petridish/legacy/conn.JPG
And just for clarification, im looking for the connector from a non-turbo...
It sounds like the one you have will work mike. if you could make sure that it looks like the pic and PM me that would be great!
Andrew
Posted: Fri Jan 27, 2006 12:28 am
by Binford
Yeah, sorry. The garbage man got to work before I did so I didn't have a chance to go dumpster diving for ya.
Posted: Fri Jan 27, 2006 11:25 pm
by petridish38
ok! found one at the local u-pull-it. The car runs now! thanks for all of your help!
Andrew
Posted: Fri Jan 27, 2006 11:37 pm
Yay.
