How to replace your electric antenna mast
dscoobydoo
Post by dscoobydoo »
Is your antenna broken? did someone bend it and/or yank it out? Does the motor still work? If you answered YES to ALL of these, then here's how to fix it.
READ THROUGH ALL OF THIS FIRST BEFORE ATTEMPTING!!!!
The motor assembly and the antenna mast are two separate parts. You can replace the antenna from outside the car, as long as the motor still works.
This is how to do this on the Sedan, as the wagon is not quite the same.
This is what you want to order. It comes with the new mast and retaining nut. Image
You will need to remove the retaining nut first Image
It will be easy if you have a tool such as this Image
or a small needlenose pliers used carefully should work also.
place the tool over the nut and remove nut.
Now, turn on the radio so the mast is extended. You will have to carefully pull the mast out. ( IF PART OF YOUR MAST IS BROKEN OFF INSIDE, GOOD LUCK ON GETTING IT ALL OUT. IF you can get ahold of a part of it, then you can pull it the rest of the way out)
Now, take your new mast and make sure the serrated part faces forward. Slowly feed it into the motor assembly. It should go in from 2-4 inches. Turn off the radio so it retracts the antenna. You might have to push the last inch or so in by hand.
re-thread the retaining nut- and VIOLA!
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
Bheinen74
Post by Bheinen74 »
this works for sedan only. I did the same. and now I have one spare working power antenna.
But...for the wagon.
The wagon has a different design; the motor is different, the mast is different (it has a ball at the end of the nylon) so you must take apart the whole assembly, not to mention the bracket is different too. I broke the motor magnets in my wagon trying to repair it.
so, guess my Wagon mast assembly (still brand new) is for sale.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
dscoobydoo
HA HA nice plug- why not post a how-to on the wagon if you have done it once?
05 GD-STI
00- GF
Bheinen74
Post by Bheinen74 »
I never did figure out the wagon way. Just ended up breaking my motor magnet assemby, and gave up.
The sedan replacement=fairly easy
The wagon replacement=pissed me off, not gonna try it again.
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
dscoobydoo
Lesson: don't break the wagon one as you are toast?
05 GD-STI
00- GF
magicmike
Post by magicmike »
I dont see how its different. the nut that holds the mast in should be the same. if that part is different you should still be able to get it off. cant be that much different.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
Bheinen74
Post by Bheinen74 »
The sedan power antenna nylon is flat/smooth, no teeth for gears, no ball at the end of the nylon
The Wagon antenna nylon has teeth in the nylon part, not smooth, and has a larger ball at the end of nylon.
altogether different, i think the secon time around i could maybe figure out the Wagon repair, but it is nothing like doing the sedan repair.
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
rallysam
Post by rallysam »
Nice writeup with many pics! Thanks.
'00 Impr RS - sold
dscoobydoo
Bheinen74 wrote:The sedan power antenna nylon is flat/smooth, no teeth for gears, no ball at the end of the nylon
Actually the sedan antenna has teeth for the gearing. But there is no ball at the end. I don't see why it would be different. I will just call the dealer and see if the antenna replacement part numbers are the same.
05 GD-STI
00- GF
JC
Post by JC »
Bheinen74 wrote:But...for the wagon.
What? Just unscrew the mounting nut turn the radio on to raise the old unit. Pull it out. Push the new one in until the ball catches. Turn the radio off and let it lower. Resecure the mounting nut. Takes like 5 mins.
[url=http://img254.echo.cx/img254/5309/pond8fq.jpg]2000 2.5RS[/url]
sullione
Post by sullione »
I just looked up that part number at www.subaruparts.com and it's listed for $46. Is that correct? Would it be cheaper to replace the whole motor/antenna? Also, where can I get a tool like that from?
James
1991 Legacy LSi sold!!!
2003 Infiniti G35
dscoobydoo
The motor assembly is a different part than the mast assembly. If your motor works, don't bother replacing it. As for the tool, all I did was drill a hole in a piece of aluminum plate and then take a regular screwdriver and hammer and create the "pins" that engage the cover screw.
05 GD-STI
00- GF
sullione
Post by sullione »
Thanks for the info. I was just pointing out that the mast cost $46. That seems pretty pricey. Where did you get yours and how much was it? I could probably engineer something to get the screw off.
James
2003 Infiniti G35
dscoobydoo
Yes, I think I paid around $46 for the mast. I did not think this is a huge cost versus having the bent one I had broken more by the cold weather and by people grabbing it. I think this mast is a common part for Import cars because it said Matsushita Electronics on it. So you might try Nissan or Toyota ( Maxima or Camry ) for an alternative price.
05 GD-STI
00- GF
sullione
Post by sullione »
Thanks dscoobydoo, I think I will go on and get one in a few weeks. It sure would be nice to get the reception I used to when I have to drive to work. Going fifty mile each way is a long and boring drive without my radio.
James
2003 Infiniti G35
MrSarcastic13
Post by MrSarcastic13 »
I might as well chime in with a question here as well, sorta on topic. What if you want to get rid of the motorized antenna alltogether and get just a normal one that stays still? How much work/how difficult is that project?
Damien
dscoobydoo
To remove the electric one for a solid mast, would probably involve removing the motor assembly, and then mounting a new mast in that location. It should be fairly easy.
05 GD-STI
00- GF
dscoobydoo
LOL- wait long enough and someone will do it and post how
05 GD-STI
00- GF
MrSarcastic13
Damn, that's why I didn't find it before...forgot to search for "Metra Multi-Application Antenna AT-GM93" my bad. :wink:
Thanks vikash.
Damien
It's the first hit when you search for "fixed antenna."
MrSarcastic13
Any idea if that will work on the wagon?
Can you take a close-up picture of where the antenna comes out on a wagon?
I would imagine it'd work as long as the angle of the sheetmetal is similar.
MrSarcastic13
Yeah, I'll have to do that tomorrow. Been meaning to add to the member car thread as it is. It is on the rear passenger quarter, close to the taillight. 1994 model.
sullione
Post by sullione »
Ok guys, I just ran across another part number for the antenna mast. It is SOA447D466. i'm not sure how accurate it is but I just thought I'd throw it out there. I'm assuming it may not be for our car since it about $20 cheaper than the one listed here with the nut but I'm not sure. Any guesses if this is a suitable sub???
James
2003 Infiniti G35
