EJ22T weight?
EJ22T weight?
Post by 1-3-2-4 »
Anyone know how much it is?
Is it manageable to be carried by one person?
The Scooby
Post by The Scooby »
i dunno but ive carried a complete engine, except the exhaust, that means alt, P/S, A/C, everything on it, me and one other guy, im not that strong too.
1986 GL wagon
EJ'ed and Lifted
Subtle
Post by Subtle »
Would you like it in pounds or kilos :?:
1-3-2-4
Post by 1-3-2-4 »
Subtle wrote:Would you like it in pounds or kilos :?:
Pounds
dzx
Post by dzx »
It's a little bulky to be carried by one person, especially with the heads on, good way to hurt yourself. I've picked my block up to put it on a table to work on and it's missing the pistons but was still pretty damn heavy.
///M
'93 Legacy SS - part out
1-3-2-4
Post by 1-3-2-4 »
Hmm and plus I heard you should not be lifting the engine by the heads anyways right?
Haha I'm Studying Legacy 777's engine teardown.
Out of all of it, Removing and putting the pistons back in scares me the most. Getting the Wrist pin out seems pretty easy (watched a video) but How about getting it back on?
dzx
Post by dzx »
My biggest problem was getting the access window to remove the wrist pins open. It's held on by a couple phillips screws I think. I believe i never did get it off, i just took the block apart a diff way, since it was blown, it didnt matter anyway
I'd hazard a guess the block and heads are around 250 but I'm not sure. It probably wouldn't be that bad if it wasn't soo bulky.
///M
1-3-2-4
Post by 1-3-2-4 »
yeah most of it is just Bulk, I can lift 250 but lol my family has a fit, thats more then Twice my body weight (I'm 125lb) 56.69Kg :P
I wouldn't recommend trying to lift the engine. Even if you can lift that much weight, it's bulky, and a good way to hurt yourself.
Lifing the short block is doable....but still a little heavy/bulky.
As for putting the pistons/wrist pins back in....they're not overly difficult. You need to try and get them lined up properly or close. Once you get them down far enough you can insert the wrist pin enough to turn the piston slightly if need be.
1-3-2-4
Post by 1-3-2-4 »
I've heard it's like 350Lb yeah maybe not a good Idea to do something like that.
Post by BAC5.2 »
I routinely lift and move and pick up STi short blocks. They are fairly light. Probably 70lbs.
I wouldn't pick up a long block though. That's asking for a back injury.
As far as getting the wrist pin access holes open, it's best if you have an impact screwdriver. It's a hand-held device that you hit with a hammer, and it turns like 1/8 a turn with every hit. Great device. It's how you are supposed to handle almost all of the screws on the engine.
Sir Yach-o
Post by Sir Yach-o »
I just shipped out an ej22t shortblock at 100lbs. The headers and turbo are the heavy items on the complete motor.
I'm saving up for my Yugo.
