"I post a lot"
Posted: Tue Mar 21, 2006 9:37 pm
by 0perose
splinter says I post more in the ashtray than all other forums combined...
and I've been thinking about it...
I believe it's because nothing really goes wrong with my legacy (aside from the waterpump that just died) and it's not really the car that I modify.. at least not in the way that you all like...I've been modifying it slightly, but to go offroad, not go fast, because going fast isn't what an awd 4cyl naturally aspirated station wagon was made for :-D
that and I love the more or less unlimited freedom of the ashtry forum 8)
Posted: Tue Mar 21, 2006 9:46 pm
by 92whitelegacy
I read all the other forums, but its so much techno babble. that i just stick to reading. Everyonce ina while ill add somthing but its not much my 2 cents arent really of help to anyone......
Posted: Tue Mar 21, 2006 9:52 pm
by 0perose
92whitelegacy wrote:I read all the other forums, but its so much techno babble. that i just stick to reading. Everyonce ina while ill add somthing but its not much my 2 cents arent really of help to anyone......
yep
Posted: Tue Mar 21, 2006 10:05 pm
by Splinter
I tend to post a lot in the other forums because it helps educate me. Ill say something that I think is true, and it turns to be way off, and I learn from it
Or in some wild circumstances, Im actually right and my knowledge (limited though it may be) will help out someone else.
I do like the 'tray tho ;)
Posted: Tue Mar 21, 2006 10:08 pm
by 0perose
well, the one thing with this board, is that it isn't very active anymore... I usually find the info I'm looking for with a search, and if I don't, I'll make a thread (doesn't happen very often) or figure it out on my own..
I got the timing right after replacing the water pump the other day... and I forgot to mark the belts, and I turned the driver's side camshaft a bunch of times...
didn't even have to get on LCO, and I've only ever taken the timing belt off this car once before
"THANK YOU LCO"
Posted: Tue Mar 21, 2006 10:11 pm
by Splinter
Speaking of which, if the crankshaft gear was off by 3-4 pegs, would the car still run ok, but get crap mileage?
Posted: Tue Mar 21, 2006 10:14 pm
by 0perose
well... it would affect the timing.. so I'm going to have to say the possibility exists... I could be wrong though
Posted: Tue Mar 21, 2006 11:15 pm
by BAC5.2
4 teeth? It SHOULD run, but not very well. At least it won't cause any collisions. I'd fix it, if I were you.
My Forester jumped 2 teeth. Idled kinda rough, and got like 18mpg.
Posted: Tue Mar 21, 2006 11:17 pm
by 0perose
actually the legacy is idling kinda rough.. maybe I did screw it up. I'll check again tonight
Posted: Tue Mar 21, 2006 11:30 pm
by Manarius
Heh..I post in a lot of of the forums....just shows my stupidity though.
I don't know..this board is pretty active compared to some of the others I'm on.
Posted: Wed Mar 22, 2006 2:00 am
by 0perose
my most commonly used phrase this week has been "I want to go home"
Posted: Wed Mar 22, 2006 2:51 am
by Imprezive
I know what you mean... :?
Posted: Wed Mar 22, 2006 4:19 am
by wiscon_mark
Hell, we don't need a tech section to have a tech discussion! The Ashtray is just an extention of the rest of the forum, it doesn't really matter.
It's not like Nasioc's OT :roll:
