Pulling the engine
Posted: Fri Mar 24, 2006 3:13 am
by georryan
Ok, so I need some advice. When I pulled the tranny in my brother's car, we left the engine in and it was all good, so I fugred when I'm pulling both, maybe I want to pull the tranny first.
I've been told recently that I should pull the engine first, and put it in last. Also, talking to Thawa, he was saying I should just pull them together, although I'm not sure I have the room in my garage for that.
Any suggestions?
Posted: Fri Mar 24, 2006 4:04 am
by gt2.5turbo
if you dont need to seperate them then pull them together... if you need to replace the engine id just pull the engine... if you need to do a clutch or flywheel or put in a new tranny i would just pull the tranny. Pulling them together is not that bad of a job but it def helps to have two people and the radiator pulled for a little more room to work with.
my .02
Posted: Fri Mar 24, 2006 4:39 am
by georryan
What if I'm doing all of the above? :)
Posted: Fri Mar 24, 2006 5:28 am
by gt2.5turbo
haha
well if your not replacing the tranny i would just leave it in there but if everything is coming out and new everything is going in just pull it as a whole it should save you some time since breaking the tranny and engine can be a bitch sometimes
Posted: Fri Mar 24, 2006 5:10 pm
by Matt Monson
Drop it instead of pulling it! If the whole assembly is coming out, use the cherry picker to lift up the front of the chassis and a floor jack to lower the engine and tranny, with both crossmembers attached, onto a dolley...
