Random CE Light
Posted: Sat Mar 25, 2006 8:07 pm
by Manarius
I pulled out of my driveway yesterday and was 2 minutes down the road and the CE light came on...then about 10 seconds later it went off. Sign of a larger problem or something I should ignore?
Posted: Sat Mar 25, 2006 8:41 pm
by Splinter
Pull the code :P
Posted: Sat Mar 25, 2006 9:06 pm
Yeah, what is this, a joke?
Posted: Sat Mar 25, 2006 9:41 pm
by Manarius
vrg3 wrote:Yeah, what is this, a joke?
No, not really. I would be more inclined to pull the code if it stayed. I thought that maybe you or someone else would know or had ever seen something like it before. But, if you're going to treat it like that..fine be that way.
Posted: Sat Mar 25, 2006 10:06 pm
by AWD_addict
I too have the phantom CEL! It comes and goes by itself, or it can be made to leave if RPMs are raised to about 3500.
[/ghost voice] And there are no codes in memory...ooo. [/ghost voice]
Posted: Sat Mar 25, 2006 10:33 pm
At least try to pull the code. Jeez. You've been here long enough to know that the CEL usually means the ECU is trying to tell you something.
Posted: Sat Mar 25, 2006 11:46 pm
by Manarius
I pulled the codes. If they are in chronological order; they came like this:
22 - Knock Sensor
24 - Air Control Valve
32 - O2 sensor (I guess this would be the one that caught me last night)
Now, suggestions? The light doesn't stay on all the time, these are just the stored codes.
Posted: Sun Mar 26, 2006 1:46 am
Wait until the light's off and clear the codes, then wait until the light turns on next and pull the codes right away.
You have a 91 non-turbo? What transmission?
Posted: Sun Mar 26, 2006 5:40 am
by Manarius
91 Non-Turbo AT.
Which one of those is the sensor that gets affected when it gets wet?
Posted: Sun Mar 26, 2006 5:42 am
by Splinter
Knock
Posted: Sun Mar 26, 2006 7:58 am
by HPP303
Im having the same random CE
checked all the sparkpluggs non has burned
and the ligth only goes on when the engien get warm
so my question is how do i pull a code to get a diagons
Posted: Sun Mar 26, 2006 8:06 am
by 206er
reset the ecu.
Posted: Sun Mar 26, 2006 8:09 am
by HPP303
its an old legacy 91 DL injector FWD, read somewhere i need a scanner to get any codes out of it , this true ?
Posted: Sun Mar 26, 2006 8:34 am
by Splinter
HPP303 wrote:its an old legacy 91 DL injector FWD, read somewhere i need a scanner to get any codes out of it , this true ?
Might want to check the stickies
Posted: Sun Mar 26, 2006 8:57 am
by HPP303
thnkx for the aswers
well i was hoping i wouldent have buy a laptop or a port for a simple car problem ,
guess its just a non oem thing anways ,
