For Sale: 1994 Legacy Touring Wagon
Posted: Tue Mar 28, 2006 1:25 am
For Sale: A 1994 Subaru Legacy Turbo Wagon with 140k miles. Lots of new parts. Runs excellent, shifts excellent. Mobil 1 synthetic used. Needs right pass. side front door and mirror, it got hit in a parking lot. Minor rust spot just starting on both rear wheel wells in the typical spots. Some minor rust spots on front fender well. Interior has no rips or tears, dash is perfect, radio cassette and cd work fine. Wheels clearcoat is peeling, and tires are pretty new. Here is a list of the recent mechanical work done. 3/17/05 - Differential oil changed, front and rear rotors and pads, calipers. 4/16/05 - replaced air flow meter, turbo valve, replaced left front headlight with a used one. 10/28/05 - New spark plugs, coolant, new radiator, water pump, timing belt, cam and crank seals, thermostat. Pictures can be provided by emailing me directly at cow562yanks@sbcglobal.net Im asking $2,695
