b.o.v. question
Posted: Wed Mar 29, 2006 4:42 am
i have heard that you cant use a blow off valve on the subaru ea82, and the ej22 because they have a map sensor, instead of a m.a.f. sensor. is this true? does anyone have pictures? thanks
A forum for 89-94 BC-BF(BJ) Legacy Owners and Fans
https://bbs.legacycentral.org/
you could, that would make it a recirculating valve though, not a blow off valve. you just can't release teh air to the atmophere after the MAF has read it.Imprezive wrote:The stock setup has the recirc valve venting to the intake of the turbo, and thats after the MAF. So why couldn't you vent a BOV to the same place?
Yes it does work fine untill you get to pushing the limits.free5ty1e wrote:Yeah, you can. I have been doing that for almost a year now. It's just rich for that instant when the throttle plate closes, sometimes results in a happy backfire (no cats). But you can release the air after the MAF has read it, and the engine still runs fine.
Once I have it to do over though I am going back to a recirculating setup with my Type S, to keep the turbo spooled between shifts.
right on the moneyscuzzy wrote:Yes it does work fine untill you get to pushing the limits.free5ty1e wrote:Yeah, you can. I have been doing that for almost a year now. It's just rich for that instant when the throttle plate closes, sometimes results in a happy backfire (no cats). But you can release the air after the MAF has read it, and the engine still runs fine.
What happens when you start pushing the limits is that the throttle plate slams shut, BOV dumps air to atmosphere, the ECU goes "OHSHITS" and pulls fuel quickly in the rich condition - the drawback is the turbo is still spooled.
if you move quickly (like you're driving hard) one punches the gas, throttle plate swings open, turbo builds boost pretty damn quickly then - but the ECU has already done the noble job of pulling fuel to keep from stalling the engine. suddenly there's alot more air than their is fuel to compensate for, and since there's a slight lag between what the O2 reads and what's actually happening in the cylinders, you run pretty damn lean for a few cycles.
pushing an engine to the max with a BOV that vents to atmosphere and an ECU that doesn't compensate for it means you can toast an engine in the lean condition.
Remember, engines predet all the time, even the factory STi predets some, but it only takes that one event to trash an entire engine.
One comment to add. The ECU is not going to be basing it's fuel calculations off of the O2 sensor in that scenario. It's going to be in open loop and basing it off of air flow and throttle position.scuzzy wrote:Yes it does work fine untill you get to pushing the limits.free5ty1e wrote:Yeah, you can. I have been doing that for almost a year now. It's just rich for that instant when the throttle plate closes, sometimes results in a happy backfire (no cats). But you can release the air after the MAF has read it, and the engine still runs fine.
