Upgraded turbo question # 2
Posted: Fri Mar 31, 2006 4:37 pm
by Subtle
With the improvements listed in the earlier post, will the stock by pass valve be able to handle the higher out put
Posted: Sat Apr 01, 2006 1:42 am
by dzx
I'd replace it with a recirculating bov.
Posted: Sat Apr 01, 2006 9:23 am
by Subtle
Re circulating---- by-pass-- two words to describe the stock valve used to relieve the pressure surge when the throttle is suddenly closed. This I have.
Question remains --how much can the factory item handle before an upgrade is required?
Posted: Sun Apr 02, 2006 10:36 pm
by BAC5.2
Dan said it correctly, upgrade from stock to a non-stock blow-off-valve that is set up to recirculate.
In the future, you can post these questions in the same thread. No need for two threads. Thanks!
