Finally filled in the antenna hole
Posted: Mon Apr 03, 2006 12:04 am
by Splinter
Hardly a professional job, JB weld and Krylon, but it should do until I can afford to get some real body work done this summer.
From more than about 6 feet away, you dont notice it unless you're looking for it.
Posted: Mon Apr 03, 2006 12:52 am
by THAWA
Nice from afar, but far from nice.
Posted: Mon Apr 03, 2006 1:14 am
by Splinter
it'll do :P
Posted: Mon Apr 03, 2006 1:48 am
by jnorion
So where's your antenna? Or did you just do away with it entirely?
Posted: Mon Apr 03, 2006 2:36 am
by Splinter
Traded it to Blackbart for a new coilpack months ago
I dont need an antenna with my CarPC system
Posted: Mon Apr 03, 2006 3:00 am
by BAC5.2
Why not sand it smooth? JBWeld has that ability.
Posted: Mon Apr 03, 2006 3:02 am
by Splinter
Probably do more damage to the surrounding paint than fixing the patch
Posted: Mon Apr 03, 2006 4:26 am
by Bheinen74
the paint match is pretty good. what paint brand and color?
I have two white legs and wouldnt mind finding a good matching color out there. anybody else know what the closest match is from a discount store for the white t-leg.
Posted: Mon Apr 03, 2006 4:30 am
by Splinter
Just the standard Krylon semi gloss white
The cans in the car right now, Ill try and grab the part number in a bit
Posted: Mon Apr 03, 2006 7:07 pm
by LaureltheQueen
that car was so clean before. :(
Posted: Mon Apr 03, 2006 7:41 pm
by The Scooby
LaureltheQueen wrote:that car was so clean before. :(
exactally, you should have waited, now you've just made it that much harder on the body man who has to now fix that the proper way when you go to paint your car...
Posted: Mon Apr 03, 2006 8:55 pm
by Splinter
Yes, I'm sure that would have been much better. Instead of a bit of additional sanding and prep work, repairing all the rust in the trunk from water seepage.
I can see how that'd be a great idea.
Posted: Mon Apr 03, 2006 9:06 pm
by sammydafish
wow that's ghetto
Posted: Tue Apr 04, 2006 12:19 am
by LaureltheQueen
coulda just left an antenna there....
Coil packs are dirt cheap
Posted: Tue Apr 04, 2006 1:18 am
by 555BCTurbo
You can get black rubber plugs in various sizes...I bet that would look a bit nicer than your creative JB Weld work :shock:
