Finally hooked up the launch control on the MSD DIS-2
Posted: Tue Apr 04, 2006 1:14 am
by biggreen96
oh my sweet baby allah!
I have it set for 3500 and it makes ~2 lbs of boost when i floor it
I mounted a little unassuming button in that panel next to the ebrake to enable the lower rev limiter.
hehe i never knew a little button could bring so much joy!
Posted: Tue Apr 04, 2006 1:21 am
Hehe, nice.
I hooked mine up to a second stock cruise control button.
Posted: Tue Apr 04, 2006 1:37 am
by biggreen96
I rally really wanted to hook mine up to the "cancel" of the cruize control so i could have both hands on the wheel but it looked a bit more difficult than placing a new button. what are your thoughts? Im unsure of how that circuit works.
Posted: Tue Apr 04, 2006 3:19 am
Have you removed your car's cruise control?
You should be able to use the "cancel" switch with some work. What year and model do you have exactly?
Posted: Tue Apr 04, 2006 5:20 pm
by DLC
That's my old car vikash, and I never hooked the CC up after the trans swap (among other things
). That's cool that you got the launch control hooked up, I'm sure it's fun.
Posted: Tue Apr 04, 2006 6:31 pm
Okay... 93 Touring Wagon. I'll try to look up the wire colors you need this evening. Bump this thread if I forget.
Posted: Tue Apr 04, 2006 9:42 pm
by BAC5.2
Launch Control in V's car was a lot of fun. That thing launched like CRAZY!
Posted: Tue Apr 04, 2006 11:12 pm
by 555BCTurbo
I am gonna need it once I put a Holset on my motor
Posted: Thu Apr 06, 2006 11:55 am
by biggreen96
bumpy
Posted: Thu Apr 06, 2006 2:22 pm
by sammydafish
Do you have a DIS-2 Plus (the new one with dials not switches) if so, are you retarding the timing too?
It seems like my DIS-2 just died... I gotta check the wiring, but seems like it might have crapped out.... kinda dissapointed about that.
Posted: Thu Apr 06, 2006 2:44 pm
biggreen96 - D'oh, sorry... I'll try to remember to check tonight. You gotta bump the thread in the evenings when I'm at home!
Junior - Really? They don't fail often... Do check the wiring.
Posted: Thu Apr 06, 2006 6:39 pm
by biggreen96
nope, I have the one with switches.
Posted: Thu Apr 06, 2006 8:23 pm
by DLC
That one I got in 01, August I think, right before my Japan trip. Got a ticket right after I installed it
Posted: Fri Apr 07, 2006 3:49 am
by magicmike
can someone explain what this does?
Posted: Fri Apr 07, 2006 3:59 am
Thanks for bumping the thread, Mike!
Okay, look under the dash for a 5-pin connector shaped like this:
Code: Select all
___ ___
| 1 |_| 2 |
| 3 4 5 |
|_________|
I think it's with the other connectors coming from the steering column. The car side of the harness connector is black plastic; I don't know what color the other side is.
Pin 1 should have a red-with-green-stripe wire on it.
Pin 2 should have a light-green-with-black-stripe wire on it.
Pin 3 should have a green-with-red-stripe wire.
Cut the red-with-green-stripe wire and make sure that the side going into the steering column does
not have +12v on it when the ignition is on. Connect this wire to ground.
Then splice into either of the other two wires and connect it to the DIS-2's blue wire.
Mike - The DIS-2's launch control feature is basically a low soft rev limiter. So you put a push-button switch between that wire and ground, and when you hold that button down you can floor the pedal and the engine will rocket up to whatever rev limit you've chosen. Once it reaches that speed, the DIS-2 starts randomly cutting spark one cylinder at a time to prevent engine speed from increasing.
Posted: Fri Apr 07, 2006 4:10 am
by magicmike
ahh ic. I do a similar thing with my left foot on the brake in my 4eat.
Posted: Fri Apr 07, 2006 4:26 am
Yesh. From the factory automatics allow you to make boost without moving.
Posted: Fri Apr 07, 2006 8:46 am
by biggreen96
awesome thank you man. dang now i will have a button that does nothing. scratch that, intercooler spray.
Posted: Fri Apr 07, 2006 4:30 pm
by Penguin
Ok I am on this "do it with factory subaru stuff" thing right now...
I wonder if you could get the same "boost without moving" effect that the auto has on a 5 speed if you mod a hill holder valve from a loyale/imp?
hummmmmm
Posted: Fri Apr 07, 2006 4:33 pm
It's not that simple. The reason you can do it on an automatic is that the engine and transmission are only loosely coupled through the torque converter. Unless you slip the poop out of your clutch, you can't load the engine with the weight of the vehicle without actually moving the vehicle.
Posted: Tue Jul 17, 2007 10:43 pm
by biggreen96
I finally had some time to play with my electrics today so I decided to mess with this.
Code: Select all
___ ___
| 1 |_| 2 |
| 3 4 5 |
|_________|
On mine the car side plug is white, the column side plug is black.
Cut the red-with-green-stripe wire and make sure that the side going into the steering column does not have +12v on it when the ignition is on. Connect this wire to ground.
this is where a problem is, the red-with-green stripe coming from the car side is hot, and activates the horn when I ground it. Scared to bejeezus out of me haha!
I tested it with the plugs disconnected.
