n00b header question
Posted: Tue Apr 04, 2006 5:54 am
by kel
im buying my first subie real soon, 96 leggy LSi sedan
Right so my question is
Will This
fit on this
2.5l NA now i know thats the RS header but will it fit
Re: n00b question ...heh
Posted: Tue Apr 04, 2006 1:27 pm
by scuzzy
kel wrote:im buying my first subie real soon, 96 leggy LSi sedan
Will This
fit on this
not without crossmember modification.
Posted: Tue Apr 04, 2006 1:34 pm
by BAC5.2
If that's a 96, then it's not an EJ25...
But yes, it will fit. I think the EJ22 in 96 was dual port...
Posted: Tue Apr 04, 2006 6:11 pm
Look at your current header. I think 95 was still dual header ports. 96 was the first year for single port headers.
If that's the case, those won't work. You'll need headers for single port exhaust heads. Borla does make some though.
Posted: Tue Apr 04, 2006 8:59 pm
by DLC
Correct me if I'm wrong, but I've heard that all Legacy EJ22s were dual port. If so, then you're fine.
Posted: Tue Apr 04, 2006 9:13 pm
by BAC5.2
Nah Dave, some of the EJ22's were single-port.
My 95-L was dual port.
I think Joshinator is right, 96 and 97 (and maybe 98?) had the single port heads on the EJ22 equipped models.
Posted: Mon Apr 24, 2006 8:57 pm
by epike7915
Not to hijack a post but I have the same type question. Will the header off of a 97-01 Impreza RS work on my 97 Legacy GT 2.5 DOHC?
Thanks,
Eric
Posted: Mon Apr 24, 2006 10:15 pm
by BAC5.2
It probably will.
Posted: Thu Sep 14, 2006 5:39 pm
by spdracr
Just need a quick yes/no answer..
Ok, so on my 92 n/a Legacy L it should have duel ports right? so any duel port header should bolt up.
Posted: Thu Sep 14, 2006 6:18 pm
spdracr wrote:Just need a quick yes/no answer..
Yes, your 92 has dual port heads. Any dual port header will fit the heads, however all the headers are designed to fit the newer cars which have different mid-pipe sections. So the header will not mate up to your mid-pipe. You'll need to get something custom done there.
Posted: Thu Sep 14, 2006 6:24 pm
by spdracr
hmm, custom exhaust in my future i'm thinking. wonder if its worth it.. anyone running headers on their 2.2l wanna chip in?
Posted: Thu Sep 14, 2006 6:47 pm
by jamal
I'm shopping right now. I think I've decided on either the OBX EL header or the Borla. Borla has the best sound, OBX might have better gains. All I hear about Borla is that they sound awesome but crack. It is apparantly fixed on the new ones but I'm still a bit iffy. The EL will change the exhaust note a bit but the clips I've heard still sounded like a Subaru.
