Its happened again.... :evil:
Posted: Wed Apr 05, 2006 3:08 pm
by ej22t
Hi all, It happened to me again..
For long story short, I had my 2nd JDM EJ20G engine installed almost half years ago and now the engine oil in the coolant system again( the reason I put the 2nd engine in because the engine oil in the coolant system). I checked the coolant all turn brown and oil seems less in the engine. I don't have blue smoke from the back and don't seems any power loss and boost is as good as normal.
Now the shop told me it maybe the head gasket is gone.
Since its my 2nd EJ20G engine and I don't wanna get another engine eventhough I could find a cheap EJ22T in town.
My decision will be:
1) Replace the headgasket
2) Replace the Metal Head gasket (where can I get and parts#)
3) Rebuild the EJ20G
4) Get the old EJ22T and rebuild it.
Guys could you tell me which will be the cheap and best way to do since I love this car and can't afford to buy another car at this moment.
Thanks for all suggestion.
Ben (1 bad luck Legacy turbo owner) :(
Posted: Wed Apr 05, 2006 5:22 pm
by NuwanD
hi ben, sorry to hear about the bad luck :?
Posted: Wed Apr 05, 2006 6:29 pm
by legacy92ej22t
I'd just replace the headgasket yourself.
Posted: Wed Apr 05, 2006 6:35 pm
by BAC5.2
Matt's right.
1) Pull motor
2) Replace headgasket
3) ????
4) Profit
Posted: Wed Apr 05, 2006 7:03 pm
by Matt Monson
replace the head gasket...
Posted: Wed Apr 05, 2006 10:44 pm
by ej22t
Thanks to all , I think I will go for replace the head gasket this time.
BTW, Should I replace the Metal headgasket or just regular headgasket?
Could anybody tell me where could I get the head gasket for the EJ20G engine?
Thanks for another help!
Ben
Posted: Thu Apr 06, 2006 2:16 am
by NuwanD
http://forums.nasioc.com/forums/showthread.php?t=977408
ej20 headgaskets for $50 ... not sure if they are the same as the older ej20g however... good luck
Posted: Thu Apr 06, 2006 3:04 am
by bmxpunk
sorry about the luck man. right now I know how you feel.
Posted: Thu Apr 06, 2006 7:24 am
by ej22t
Thanks NuwanD. We should have a meet soon since haven't see you and the other legacy guys long time ago. Missing you guys!
Hi Bmxpunk... hopfully you don't have to suffer the same problem as I had.
Does anyone knows about which head gasket I should take and also, whats the thickness that I should use on this engine!
Thanks for your reply!
Ben
Posted: Sat Apr 08, 2006 10:40 pm
by EJ20TMAN
Use metal headgaskets from a EJ20R engine, will try and get u the part number
Posted: Sun Apr 09, 2006 1:42 am
by ej22t
Thanks EJ20T man, I will looking forward to your post!
Ben
