Autotronic replacement board
Posted: Thu Apr 06, 2006 6:14 pm
I'm assuming the "Subaru WRX 1994 to 1996 replacement board." is OBD2??
http://www.autronic.com/page_files/mits ... subaru.htm
Re: Autotronic replacement board
Posted: Thu Apr 06, 2006 6:15 pm
by scuzzy
Legacy777 wrote:I'm assuming the "Subaru WRX 1994 to 1996 replacement board." is OBD2??
I don't think so.
Posted: Thu Apr 06, 2006 6:35 pm
OBD-1.
94-96 WRXes ECUs are actually very similar to those in 93-94 non-turbo North American Legacies. Other first-gen JECS ECUs are also similar.
Posted: Thu Apr 06, 2006 9:43 pm
by BAC5.2
Yep. The JDM WRX went OBD2 in 1997. A Friend has an impreza with a 94 WRX swap (controlled by an Apex PowerFC). It ran (an 11.8 I might add) properly, and was using the turbo that is in my car now :).
On to something Josh?
Posted: Thu Apr 06, 2006 9:45 pm
I think you'd actually want to use a 97-98 board, though. I think they have the same basic pinouts as our stock ECUs, unlike 94-96 WRXes which had 4-channel ignitions.
Posted: Fri Apr 07, 2006 5:46 pm
Would any of those boards work with the turbo legacy ECU?
Or would I use a 94 n/a ECU with that board and then tune?
Vikash, so you think the 97-98 board would be better....would there be issues since they went to OBD2 in 97?
BAC5.2 wrote:On to something Josh?
Not sure...there's a tuner in town that sells autotronic I believe. No idea of the cost or if this stuff would work....I'd more or less like to know the if it'd work.
Posted: Fri Apr 07, 2006 6:00 pm
Realize that those boards aren't meant to work with stock ECUs -- they're meant to replace stock ECUs. They're full standalone ECUs that just fit inside the stock ECU case.
I don't think they'd fit inside a Hitachi ECU case, but they should fit inside any of the JECS ECU cases, I would imagine. Maybe with a little effort.
I don't think they actually went to OBD-II in 97. I think it was in 99. I might be wrong though -- Phil, where did you get that info?
Posted: Mon Apr 10, 2006 6:53 pm
Gotcha....I thought they were add-on boards.
Posted: Mon Apr 10, 2006 10:36 pm
by BAC5.2
It may have been 99. I seem to remember hearing someone say it was in 97. But heresay isn't always right.
I know at least 94 was OBD1. Brent's yellow car has a 94 ECU in it.
