MAF after the turbo
Posted: Sat Apr 15, 2006 7:27 am
by thehookeup
so do you think that i could put my MAF after my turbo. it would still be reading the same amount of air flow. in my opinion it would be more accurate. and just hook up a filter before the turbo.. call me crazy but i think that it could work.
what do ya think
FYI i have a front mount. nearly just like doug vincent's just i have a turbo. well i almost have a front mount. i just cant get the dame bumper on. bring out the cutting wheel.
Posted: Sat Apr 15, 2006 7:44 am
by Kelly
The problem is that the MAF also reads intake air temp. You put it after the turbo, it reads hot air, and pulls back timing. Tuners have played with post turbo MAFs for years. Usually you would use two MAFs. One pre turbo, and only use the temp sensor, and then post for flow.
Its really only necessary for very large, high flowing turbos with cams and large displacement. It doesnt always work. Theres some actuall fluid dynamics involved that not all tuners can afford.
Its cheaper to switch to a speed density type fuel system, and get rid of the MAF alltogether.
Thanks for playing the MAF game.
Posted: Sat Apr 15, 2006 8:32 am
by douglas vincent
If you are FMIC, then you can stick the MAF after the intercooler.....
Posted: Sat Apr 15, 2006 7:51 pm
by thehookeup
thanx guys i appreciate it.
Posted: Sun Apr 16, 2006 4:07 am
rallitektech wrote:The problem is that the MAF also reads intake air temp. You put it after the turbo, it reads hot air, and pulls back timing.
Nope, not on our cars. Temperature is measured only to compute airflow, and never leaves the sensor.
Posted: Sun Apr 16, 2006 6:11 pm
by Kelly
Oh, I just assumed.
I guess thats kinda good to know then.
Posted: Thu Apr 20, 2006 11:29 pm
vrg3 wrote:rallitektech wrote:The problem is that the MAF also reads intake air temp. You put it after the turbo, it reads hot air, and pulls back timing.
and that is the beauty of MAF based systems
