CES BEP VF11 vs. VF12
Posted: Sat Apr 22, 2006 7:33 am
by kleinkid
I currently have a CES TBE with the BEP for the stock VF11 installed. I will be putting in a VF12. Will the BEP for the VF11 work for the VF12? I e-mailed CES Racing and he responded that they are not familiar with the VH12 there in Australia. Now, he did in fact say VH12 in his response. I wonder if he just misread my e-mail, VF read as VH, or what. I e-mailed him again and said that this VF12 I have came from Australia and they were used in the Liberty RS. Have not heard back from him yet.
Posted: Sat Apr 22, 2006 1:16 pm
by legacy92ej22t
The BEP that came with your system should work. If anything, the seperating flange may be slightly short if the VF 12 has a deeper turbine outlet/wastegate area but it will defintely work either way.
The other BEPs that I have are for the VF23. They have a longer seperator but it's also at an increased angle. I guess it depens on what exhaust housing comes on the VF12. If it's the same as the VF11 then I wouldn't worry about changing it. If it's the same exhaust housing on the VF12 as the VF23, then you might want to order one from Trevor ( I have two but they're both spoken for already).
Posted: Mon Apr 24, 2006 8:19 pm
by georryan
I'm running the BEP on my vf8, which is probably identical to the vf12. You should be fine.
