WANTED:EJ18 CARB INTAKE MANIFOLD
Posted: Tue Apr 25, 2006 1:19 am
by monstaru
title says it all.i would love to get my hands on one of these.i am usually over on the USMB but am trying to cover all of my options. thanks guys,cheers,brian
Posted: Tue Apr 25, 2006 1:43 am
by 206er
are you gonna set up a distributor too or use the stock ignition?
Posted: Tue Apr 25, 2006 2:02 am
by monstaru
i have a disty setup.thanks,brian
Posted: Tue Apr 25, 2006 5:07 am
by legacymax
When did they use an carb with an EJ18?
-max
Posted: Tue Apr 25, 2006 6:16 pm
by DLC
Outside of the US, in the Legacy and Impreza models, usually in Europe.
Posted: Tue Apr 25, 2006 7:14 pm
by legacymax
ok.
-max
Posted: Tue Apr 25, 2006 9:34 pm
by EJ22_SLO
Here in Europe we have "carbed" (monopoint injection) EJ18, Legacy 1st and 2nd gen. In Leone (EA82) we have two types of engine - one pure carb, and the other one is monopoint injection...
If you're looking for EJ18 intake manifold like the bottom one on pics below (upper is from EJ22 N/A)... perhaps i could find one.
Posted: Tue Apr 25, 2006 10:45 pm
by monstaru
as long as it will bolt up to an ej22 i will take it.of course i would compensate you as well.what would you take for one and shipping would be to
spokane,washington 99202 USA
thanks, brian
Posted: Tue Apr 25, 2006 11:04 pm
by EJ22_SLO
Ej18 - at the picture wont bolt on Ej22 engine;
problem no1: you can see Ej18 has integrated "water pipe" (EJ22 engine has separated water line),
problem no2: i can tell you it has much smaller diameter.... won't fit...
problem no3: IAC valve, vacuum...
i can take some more comparation pictures and measurements if you want... but i'm 98% it wont fit. at least not without modifications...
Posted: Tue Apr 25, 2006 11:24 pm
by monstaru
the water jacket can be taken care of.the smaller diameter pipe is not really a concern.i like to fabricate things.also,from what i hear,it should be a direct bolt up as far as where the heads meet the manifold.thanks, brian
do you have a picture of the bottom?i would love to see it.thanks again,brian
Posted: Tue May 02, 2006 1:14 pm
by monstaru
bump.........a monopoint or carb manifold is suitable now.
Posted: Wed May 03, 2006 8:13 pm
by EJ22_SLO
