Modifying interior cooling/heating (removal)
Posted: Sun Apr 30, 2006 2:05 am
by Splinter
I removed my AC back in february, at least, most of it.
I took out the condensor, the compressor, and the cylinder on the passenger strut tower
What else can be removed?
EDIT: Direction of thread changed
Posted: Sun Apr 30, 2006 5:21 am
by Bheinen74
The AC switch on the hvac controls :roll:
Posted: Sun Apr 30, 2006 5:29 am
by Splinter
I thought there was something behind the glovebox :roll:
Posted: Sun Apr 30, 2006 11:44 pm
you can remove the evaporator if you want.
You'll need to plug the holes in the firewall as well as the holes on the evaporator box.
Posted: Tue May 02, 2006 1:55 am
by Splinter
Legacy777 wrote:you can remove the evaporator if you want.
Is that the big black box behind the glovebox?
Posted: Tue May 02, 2006 2:49 am
by Splinter
I cant actually remove the evaporator, because the blower uses it as a duct for the rest of the heating system
Lame.
Posted: Wed May 03, 2006 12:23 am
by Splinter
Would it be possible to mount the blower right onto the heater core?
How do cars without AC have their under-dash heating setup?
Posted: Thu May 04, 2006 3:22 am
by BAC5.2
I modded the title for clarification.
Posted: Mon May 08, 2006 5:33 pm
by PRT
Splinter wrote:I cant actually remove the evaporator, because the blower uses it as a duct for the rest of the heating system
Remove it out of under the dash, split it open and remove the evaporator from inside, then you can still use it as a duct.
Posted: Mon May 08, 2006 8:27 pm
by Splinter
Yes but that doesnt actually save any space :)
Posted: Mon May 08, 2006 9:10 pm
by 0perose
saves weight though
Posted: Mon May 08, 2006 9:12 pm
by Splinter
like 4lbs...
anyway
Im trying to save some space so I can move my carPC under the dash
