DIY: HD rear swaybar mounts (holy crap thats a big pic!)
Posted: Tue May 02, 2006 5:41 am
What do you get when you at a Welder, plasma cutter, 1/8th" steel, and about 2 hours of labor together??? Rear HD links!!!
I'm kinda on a budget when it comes to buying stuff for my car, and along with the 24mm rear sway bar I just ordered, I decided I'll probably need some heavy duty sway bar mounts. So instead of spending the $100+ on the whiteline setup, I just modified the stock mounts.
If you dont have a plasma cutter or some kind of metal cutter this is sort of impossible. Anyway you'll need a peice of metal about 6"s by 10"s. Or anything that you can cut 2 plates out of will work.
They aren't painted yet!!
So, after I traced the outside of my mount on the peice of sheetmetal I used my handy plasma cutter to cut the rough shape out, then I used my stationary grinder to fit it a little better to the mount.
also added some little support welds on the inside to ensure strength....i guess...
All the pics are of the finished product, I was too lazy to document it with pics step by step. And aside from have stronger mounts, I feel like I didnt totally waste this day doing nothing... The welds are a little ugly, but form follows function and its under the car so who cares. I'm debating wether to add any more reinforcement to where the mount bolts to the frame. We shall see.
