06 legacy gt sedan suspension in my 93 legacy wgn?
Posted: Wed May 03, 2006 12:52 am
by brodie.gordon
just wondering if some 2006 legacy suspension would work in my 93 legacy wagon? could i use my perches if the springs are different? i am running factory suspension and was told that i need to replace it.
thanks,
brodie
Posted: Wed May 03, 2006 4:29 am
by greg donovan
nope, the rear suspenion is totally different between the two.
the 06 has a very small comapct multilink setup.
Posted: Wed May 03, 2006 5:43 pm
by DLC
Starting in 2000, the Legacy uses a multilink rear suspension. The Impreza is likely going to this setup in its next big revision as well.
Posted: Wed May 03, 2006 6:10 pm
by Yukonart
DLC wrote:Starting in 2000, the Legacy uses a multilink rear suspension. The Impreza is likely going to this setup in its next big revision as well.
Yup, the descriptions I've seen for that are "a shortened wheelbase version of the new Legacy chassis".
Posted: Wed May 03, 2006 7:42 pm
by Brat4by4
That is exactly what the original Impreza chassis was...
