WTB: All parts to convert 92 Legacy wagon from air struts
Posted: Sat May 06, 2006 10:27 pm
by handson
I need to convert my new 92 Legacy wagon from air struts to conventional struts.
Basically, I need all the pieces.
The sooner the better. I had just got rid of my 91 Turbo, and I got a great deal on this 92 wagon with 65K on it because the struts are DOA.
Thanks!
Posted: Sat May 06, 2006 10:42 pm
by handson
What fits? what setups can I use?
Posted: Sun May 07, 2006 5:37 pm
by DLC
You need the strut, spring, top hat and top mount. If you want to use used parts, simply go to a salvage yard and purchase the entire assemblies from a 92-94 wagon and swap them in. If you want to replace the struts with new units, get everything anyways, and swap the struts.
You can use later model Legacy and Impreza parts, but you'd be better off with near-year parts.
Posted: Mon May 08, 2006 4:55 pm
by handson
Would a set from a 95 wagon fit?
Posted: Mon May 08, 2006 6:32 pm
by DLC
It should fit, yes.
