swapping 92 L engine into 91 LS wagon?
Posted: Mon May 08, 2006 5:00 am
yo dudes,
just bought a n/a 91 wagon ls that needs an engine. wondering if the engine out of my n/a 92 sedan will bolt in directly? actually im curious about the ecm and sensors: are they all the same or do i need to switch any of them? and if i do, is the wiring harness the same or do i need to update that as well? also, what tips do you guys have for the swap? besides changing the oil pump o-ring, front crank seal and water pump???
thanks,
shaun
thanks,
shaun
