knock sensor code, and new pics
Posted: Tue May 09, 2006 8:11 pm
by thehookeup
Posted: Wed May 10, 2006 1:02 am
by napphappy
After my "g" swap I had a random Knock sensor code. If you dont have the updated part, now would be a good time to do it.
After I replaced the sensor the code went away.
Those Lifters can be noisy espesially at first. If they are noisy enough it can cuase the ecu to pull timing. Im not sure if it would cause the cel though.
Posted: Wed May 10, 2006 1:32 am
by thehookeup
i pullled the sensor and i have a crack in it. i got a hook up on one, hopefully be running tomorrow just fine.
Posted: Wed May 10, 2006 6:55 pm
by napphappy
cool, keep us posted
Posted: Wed May 10, 2006 7:45 pm
by thehookeup
done as done. knock on wood. CEL went off when i put the new knock sensor in. Its keeping temp. i also cleaned up the engine bay and took off all the electrical tape that i had in various areas. and i also cleaned up my intake so i dont have that nasty hose with the bolt in it. haha
all i have to do now is fabricate a plate for the intercooler or find a good way to bolt it up so its not hangn
heres a pic of my old knock
Posted: Thu May 11, 2006 10:24 pm
by dzx
looks like every knock sensor on a legacy I saw last time I was at the junkyard
