Bolt stuck on down pipe
Posted: Wed May 10, 2006 10:06 pm
by waldo320
Well trying to take the down pipe off today and totaly stipped one of the nuts. Used penitrating oil nothing, vice grips nothing, has anyone used one of those nut extractor kits not drill outs? Tried to take turbo off cant due to up pipe bolt touching down pipe, well any sugestions would help thanks. And yes I did use a 3 foot breaker bar!!!
Posted: Wed May 10, 2006 10:39 pm
by legacy92ej22t
Grind off the nut and then replace the stud.
That or torch it off.
Are you replaceing the DP?
Posted: Wed May 10, 2006 10:49 pm
by waldo320
yah replacing the downpipe with a 3", could you explain how i replace the stud.
Posted: Wed May 10, 2006 10:58 pm
by legacy92ej22t
Well it depends on if the stud/bolt you're having a problem with is a stud/nut or bolt/nut. If it's a bolt then you just replace the bolt and nut. If it's a stud, once you have the turbo out you can heat the stud up and thread it out or drill it out and replace it with a new one.
I had a bad stud once and I just replaced it with a hex head bolt.
Posted: Thu May 11, 2006 1:43 pm
by magicmike
dont know the part number but you can get the studs at the dealer.
Posted: Thu May 11, 2006 4:53 pm
I've used nut extractors to remove those nuts before. They're roughly the right size to grip the nut, and have left-handed flutes in them so they grip the nut harder as you turn counterclockwise. I got a set from Advance Auto Parts that worked great. I also got a Craftsman set from Sears that sucked. I think the primary difference was that the Craftsman ones didn't have a lip on them so you couldn't use a socket wrench to press them down onto the nuts.
The top two fasteners of the turbo are nut-and-bolt combinations. The other three are studs and nuts. If you damage a bolt it's no big deal since it can be replaced easily. If you damage a stud, though, it can be a little harder to remove the stud and find a replacement. It's possible, though... I've gotten studs out with vise-grips and also by tightening two nuts against each other on the threads and then using an impact wrench.
If you look a little you should be able to find replacement studs at an auto parts store or even a good hardware store. Toyotas use the same studs.
These nuts are stainless steel, so they can be hard to cut.
If you can manage it, it's better to replace a stud than to switch to a bolt.
Posted: Thu May 11, 2006 6:25 pm
by BAC5.2
I have the nut extractors that Vikash has used (I think Vikash has them too?) I got mine at Pep-boys, and they have come in more handy than not.
I've gotten completely rounded bolts off with them.
I forget who makes them though.
Studs and nuts are stronger than a bolt is. If properly torqued, you can get some outrageous strength out of a stud/nut combo.
Posted: Thu May 11, 2006 9:56 pm
by dzx
I used an air chisel to get the nut off of my uppipe two days ago. It wasn't very easy though, the material they are made out of is relatively hard.
Posted: Fri May 12, 2006 1:13 am
by BAC5.2
Stainless.
Posted: Fri May 12, 2006 1:23 am
by dzx
I think they have some nickel in them too but i might be wrong.
ANTI-SEIZE
Posted: Fri May 12, 2006 1:38 am
by Bheinen74
i bet you can get the nut off, without ruining the stud, with a tool or by chiseling it off, etc.
. If you get the nut off, then i would recommend retapping the stud to make sure it is good. Also, when you put this back together, put ANTI-SIEZE on the stud, so if you ever have to remove it again, it will come loose.
Posted: Fri May 12, 2006 4:11 am
by waldo320
Yah will definitly be putting some never seeze on the new bolts, I will take a wak at it tommorw and let you all know what worked. Thanks for all the sugestions.
Posted: Fri May 12, 2006 10:05 pm
by waldo320
Well I took the oportunity to buy a toy today an air hammer, got home went to town on the bolt , and low and behold got a wrench on it and it came off nice and easy!!!!! Thanks. 3" down pipe are amazing, I am running it straight right now WOW is it loud!!! My car is seriously 1/2 sec to a second faster boosting 2 pounds more and WOW thats all I can say.
