Don't have a stop lamp? Want one?
Posted: Fri May 19, 2006 6:52 pm
by Splinter
There's a bulb blank in the gauge cluster behind the stop-lamp cutout. Grab a holder and a 74 bulb, and it should work
Posted: Sat May 20, 2006 3:19 am
by jnorion
Maybe a stupid question, but what's a stop-lamp?
Posted: Sat May 20, 2006 7:35 am
by Binford
jnorion wrote:Maybe a stupid question, but what's a stop-lamp?
I'm sorry, but I'm soooo tempted to quote that in my sig!
Oh yeah, DRUNK POST!!!
Posted: Sat May 20, 2006 7:42 am
by jnorion
I'm not drunk and I'm being serious. I can't think of anything in my gauge cluster that I would call a stop lamp. Brake lights come to mind but I don't have one of those in the cluster, nor did I see a warning light relating to them.
But taken as a single line the way you just quoted it, that looks pretty damn funny.
Posted: Sat May 20, 2006 8:26 am
by douglas vincent
My wifes sedan has a stop lamp. What the hell is it?
Posted: Sat May 20, 2006 8:51 am
by bmxkelowna
ebrake light if im corect
Posted: Sat May 20, 2006 9:32 am
by douglas vincent
When the brake is pressed, the "stop lamp" light comes on.
Posted: Sat May 20, 2006 5:48 pm
by jnorion
I think that would really annoy me... I would always think it was a warning light of something wrong.
Posted: Sat May 20, 2006 5:58 pm
by Splinter
Its a light that comes if one of your brake lights burns out, if Im not mistaken.
The handbrake light is the exclaimation mark with the circle..
Posted: Sat May 20, 2006 6:01 pm
by IronMonkeyL255
Basically.
At least that's the way it is in my '91.
The brake light is for brake fluid level and e-brake, while the Stop Lamp light is for letting you know if you have a light out.
Posted: Sat May 20, 2006 6:48 pm
by douglas vincent
All my lights work, so its annoying.
Posted: Sun May 21, 2006 7:17 am
by IronMonkeyL255
How would it be annoying? It never comes on until you have a light out........
Posted: Sun May 21, 2006 7:35 am
by douglas vincent
No lights out, all work, thats why its annoying. And the break fluid resioir is fine too.
Posted: Sun May 21, 2006 7:45 am
by Splinter
Sounds like yours is broken then
Posted: Sun May 21, 2006 5:30 pm
by IronMonkeyL255
whos?
Posted: Sun May 21, 2006 5:37 pm
by Splinter
dougs
Posted: Sun May 21, 2006 6:38 pm
by jnorion
I checked last night and I have one and it turns on with all the warning lights in the "on" position but I've never seen it other than that.
Posted: Sun May 21, 2006 6:58 pm
by scuzzy
some systems use a two stage bulb - whereby one element in the bulb can burn out and the other work - thus it looks like the light is fine, but when you step on the brakes either it doesn't light the other element and the light stays teh same intensity as the other brake, or it goes out completly - depends on how the brake light system is setup.
If your stop lamp is lit on your gauge cluster, either you have a problem with the switch that activates the stomp lamp on the ebrake, on your brake pedal, or one of your lights is burned out.
