Power Steering
Posted: Sat May 20, 2006 8:29 am
by Carbix
I just go the car and well i find that the power steering is a lil tuff. It almost feels like there is none. But i know there is and when im stop i can really tell that it still works. But over all i feel that there is a lot of force being put back. At least more then say my sunfire.
Posted: Sat May 20, 2006 5:11 pm
by Project_Legacy
check and see if you have enough fluid in there.
Posted: Sat May 20, 2006 10:38 pm
by 206er
the legacy is a little less assisted than other cars, maybe just less than you are used to.
I for one LOVE the steering of my car.
Posted: Sun May 21, 2006 3:08 am
by evolutionmovement
If it didn't work at all you'd need two hands to turn the wheel when stopped and have to work it hard even when going.
Posted: Fri Jun 02, 2006 4:48 am
by Carbix
yeah no i know it was working. But after turnning about 40deg' it would become more and more harder. So i looked at the dip stick and i found out it was low and boy was it. it took half a bottle to fill it back up. Now the one thing that im not sure about is that i got just normal fluid. Not the stuff it said on the cap. Is this bad it was steering fluid and good stuff?
Posted: Sat Jun 03, 2006 2:59 am
by entirelyturbo
You used power steering fluid?
I would think you'd be fine with that.
Mazda actually has quarts of fluid that are labeled as such: Mercon V Transmission and Power Steering Fluid...
