Will this work...?
Posted: Wed May 31, 2006 9:06 pm
by supernoob
I just bought a 98 Leg Wagon with rod knock. I've got a 90 EJ22e block with 95 EJ18 heads on it sitting in my garage. Will the manifold from the 98 work on the 95 heads. If it doesn't, can I gasket match 'em. Or should I use the 95 manifold? Thanks.
Posted: Wed May 31, 2006 9:22 pm
by sammydafish
2.2 or 2.5 in the 98? If it's a 2.2 it might fit, pretty sure the intake is the same, the exhaust will be different though, the 2.2 changedto single port in 96.
if the 98 wagon is a 2.5 it won't fit, you'd be better off with another EJ25
Posted: Wed May 31, 2006 9:34 pm
by supernoob
[quote="sammydafish"]2.2 or 2.5 in the 98? If it's a 2.2 it might fit, pretty sure the intake is the same, the exhaust will be different though, the 2.2 changedto single port in 96.
if the 98 wagon is a 2.5 it won't fit, you'd be better off with another EJ25[/quote]
Thanks sammy, its a 2.2.
