Saab IC install, very worthwhile
Posted: Tue Jun 13, 2006 5:57 am
by Natoe
Got my saab intercooler and piping from blackbart today (thanks!) installed and put boost at 12lbs....
really amazing difference in power(WOW) and spool time(just a tad longer), it is really great and worth your while.
i also relocated the coolant tank a lil while back, 5ft of 1/2" hose and 2ft of 5/16" hose and i used every inch it was perfect. i suggest getting just a lil more hose than that though.
like my duct tape air splitter?
pics: (in my impreza)
Posted: Tue Jun 13, 2006 6:06 am
by bmxkelowna
wow looks really good
is moving the coolent tank nessisary?
Posted: Tue Jun 13, 2006 6:09 am
by Natoe
i dont believe it is necessary, since many have gone without moving it. but i see no reason not to move it, it gets very close to the intercooler in stock location, and it only costs 8 dollars an 15 minutes to lengthen the hoses to where i mounted it and not risk breaking off the nipples.
Posted: Thu Jun 15, 2006 8:16 pm
by Radial GT1
Or 3 broken plastic nipples..... Like mine were when I bought the car.
That looks great! I will be doing the same very soon.
Posted: Fri Jun 16, 2006 3:53 am
by legacy92ej22t
Right on!
I remember when I installed my first TMIC (it was a saab 900 too) and it was soooo cool. The sound is awesome too, huh?
Posted: Fri Jun 16, 2006 4:33 am
by IronMonkeyL255
I dan't wait to get my WRX i/c installe dand crank the boost now.
Posted: Fri Jun 16, 2006 5:00 am
by Natoe
yeah i would like to do more now since this turned out so great. how much boost do people usually put through the saab IC's with the vf-11? im gonna rig up a VRG FCD here soon. im running at just below boost cut, 12lb's.
i would really like to get a wrx IC to work, might try that next, using the stock y pipe and all.
as for sound, turbo noise isnt much louder since i already have a downpipe it is the noisiest. the stock BPV makes a flutter noise which is kinda funny or "cute" hahaha
Posted: Fri Jun 16, 2006 5:39 am
by IronMonkeyL255
That's all I'm gonna probably run, at least until I get bored and build the FCD.....
Posted: Fri Jun 16, 2006 5:41 am
by Natoe
12 is all it lets you run for more than 3 seconds, till you have the FCD
Posted: Fri Jun 16, 2006 5:47 am
by IronMonkeyL255
I know that.
I figure I'll get bored with the power I'm making, then build the FCD so I can up it a bit more.
I have seen poeple running as much as 15 PSI with a similar setup on the stock turbo, but that's pushing the efficiency range of the turbo.
Posted: Fri Jun 16, 2006 5:49 am
by Natoe
interesting, but doesnt that max out the MAF signal? and can fueling keep up with 15 pounds?
i was almost maxxing my MAF at 10psi non intercooled (5.1V), havent checked again yet.
Posted: Fri Jun 16, 2006 5:57 am
by IronMonkeyL255
I think that's pushing the fuel system.
I'm honestly not sure where the MAF signal tops out. I'm gonna get EM, larger injectors (already got the fuel pump) and a larger turbo before I try anything too drastic, though.
Either that, or do an STI drivetrain swap. whatever I get the money and time for.
Posted: Fri Jun 16, 2006 5:59 am
by Natoe
ya i am debating going EJ20G.. but im not sure yet, maybe just blow this one up first.
i have a wrx pump in, but would like some bigger injectors and some kinda EM.
im guessing that my MAF sensor is maxxed out, which just means it will start running lean up top, feel faster, and then blow up haha. might try gettin a wrx top mount on there again, just for fun.
Posted: Sat Jun 17, 2006 7:08 am
by Binford
I don't think your MAF should be maxing out so soon. I've got a TD04 at 16psi on my stock MAF, although I've never measured it's voltage. IIRC, someone on here measured theirs with a 16G and maxed out at about 15 psi. I do have a bad memory though!
Posted: Sat Jun 17, 2006 7:46 am
by Natoe
hmm interesting, i just assumed that its a 5.4V maf or something, since i was getting 5.1V at high rpm in 4th at 10psi non intercooled, i thought the increased airflow would max it, can anyone else chip in their thoughts on this?
Posted: Sat Jun 17, 2006 11:31 pm
If you're reading that from the scan tool.....it's not right.
Posted: Sat Jun 17, 2006 11:48 pm
The scan tool reports 5.10 volts when the sensor's range is exceeded.
Posted: Sun Jun 18, 2006 1:06 am
by Natoe
ok thanks, so im maxxing the MAF
the scantool showed it slowy increasing to like 4.9 and then at like 5750 in 4th @ 10psi it went to 5.1...
so would bigger injectors and an SAFC help here? i could tone down what MAF voltage the ECU sees, so it wouldnt fuel as much except that with bigger injectors i could find a middle ground.
Posted: Sun Jun 18, 2006 1:10 am
No. Turning the voltage down won't increase the sensor's range.
Posted: Sun Jun 18, 2006 1:12 am
by Natoe
doh, im thinking about this wrong. using a different MAF, say an NA plastic cylinder one, can you tune that with an AFC? or what else could i do? ill look around some more, im sure the answer is out there.
thanks
Posted: Mon Aug 21, 2006 5:41 am
by boro
not to dig up something so old, bit I just got a Saab TMIC, I need some advice on IC piping. What did you guys use?
Saab I/C
Posted: Sun Nov 05, 2006 6:15 am
by dbuzz77
ya, where did you get the transition pieces from the i/c to the other stuff?
Posted: Sun Nov 05, 2006 7:09 am
by Natoe
just fab up a pipe to go most of the way that has a fitting on it for the BOV hose. then find some hoses that can slightly change diameter to tighten down to the IC and turbo outlet.
