92 and up 5MT swap question
Posted: Thu Jun 29, 2006 12:58 am
by Splinter
I figure its about time I finish up the wiring for my swap, but theres no pigtail for the pin 20 on the B48 connector, how can I ground it to set the AT/MT indentifier?
Posted: Thu Jun 29, 2006 1:06 am
Steal an unneeded pin from somewhere else. Maybe the Park Switch pin.
Posted: Thu Jun 29, 2006 1:36 am
by Splinter
Any tips on removing them from the connector?
Posted: Thu Jun 29, 2006 6:21 am
Wait -- I thought you would have a wire there stock, and now have to cut that wire.
The wires are easy to remove. It'll be clear when you look at it up close. You can use two small flat-head screwdrivers to release the latch that holds the entire row down, and then you use a very small flat-head screwdriver or a large sewing needle to release the individual pin.
But double-check -- I'm pretty sure all you have to do is cut the wire that's already there.
Posted: Thu Jun 29, 2006 6:38 am
by Splinter
no, the 91s have a wire to cut, the 92s have a pin to ground
Posted: Thu Jun 29, 2006 6:54 am
I thought that wasn't the case for turbos. If you've verified this directly, I must be wrong.
Posted: Thu Jun 29, 2006 7:14 am
by Splinter
Theres no pin in the #20 position on the connector specified, thats all I know for sure.
Posted: Thu Jun 29, 2006 8:24 am
by gt2.5turbo
mines a 93 and i just cut the wire.... no issues
Posted: Thu Jun 29, 2006 10:25 am
by Splinter
wtf
Why doesnt mine have a wire?
What colour is it supposed to be?
Posted: Fri Jun 30, 2006 3:45 pm
The turbos should be setup the same way as the 90-91 n/a's, and how the FSM states.
I'm using a 92 tleg ECU, and have disconnected the wire going to that pin.
Have you checked with vikash's scan tool to verify whether the ECU is in MT or AT mode?
Posted: Fri Jun 30, 2006 4:57 pm
Black with a white stripe, I believe.
