fuel pressure
Posted: Sun Jul 09, 2006 8:41 pm
by georryan
So what should our fuel pressure be? I just got a pressure gauge that reads to 100 psi and I want to test and see if my pressure regulator is going out, but I'm not sure what the pressure should be. Does anyone know?
Posted: Sun Jul 09, 2006 9:21 pm
by napphappy
At Idle I think it should be about 26-30 PSI.
Posted: Sun Jul 09, 2006 10:01 pm
by georryan
So if I rev up the engine should hte psi go up? Cause it goes up slightly and then drops back down to the idle almost right away, even if I'm sitting at 3k-4k rpms.
Posted: Sun Jul 09, 2006 10:02 pm
by georryan
Also I'm sitting at 31 psi at idle. Granted, this is with my car acting fine, I want to get it to act up and then see what it is doing.
by scuzzy
georryan wrote:So if I rev up the engine should hte psi go up? Cause it goes up slightly and then drops back down to the idle almost right away, even if I'm sitting at 3k-4k rpms.
it should stay constant, the slight increase is nothing to be worried about.
Posted: Sun Jul 09, 2006 10:37 pm
http://bbs.legacycentral.org/viewtopic. ... l+pressure
Fourth paragraph.
Your fuel pressure is based upon engine vacuum. If your vacuum at idle and 3-4k is similar, then fuel pressure should be similar.
Posted: Sun Jul 09, 2006 10:43 pm
by Threshld1
so would it be a good thing if i run 30 psi solid at idle but when i rev it, it goes to nearly 38psi and holds?
Posted: Sun Jul 09, 2006 10:57 pm
by georryan
Yeah, the wires you speak of aren't the problem. I've already routed them around that connector. If they were the problem my car would die, not sputter.
I have about 31 psig at idle, 41 without the vacuum line connected on the fuel pressure regulator. I wish my car would act up again so I could see what it was doing then. I also wish I was able to bring that fuel pressure gauge into the cab of the car, but I sappose that isn't very safe.
Posted: Tue Jul 11, 2006 7:39 pm
Shim the hood up and tape the gauge to the outside of your windshield.
