AGX w/ Whiteline control
kleinkid
Post by kleinkid »
Have AGX with Whiteline control springs. I have noticed that there is a chirping sound from the rear when taking corners a little hard. 15" wheels, stock tire size. Front set at 2, rear at 3. Don't like too stiff for around town. It does sound like the tires are briefly rubbing on something. Went under and inspected and did not see anything bent or broke or loose. What is going on?
Chirping like tires or squeaking? I get some squeaking from the rear going over bumps with the same setup. Front at 2, rear 4.
kleinkid
Post by kleinkid »
Sound like tires chirping when rubbing on what ever they might be rubbing on. Not squeaking sound. Did not used to make this sound. These struts and springs have been on for about nine months.
Might be the coils on the springs hitting each other and making noise. My whitelines did make some noise, but I don't recall it being a chirping sound.
I used the coil quieters from WL and wrapped it around the areas where they were prone to touch.
Also, have you checked brake lines, and the body side of the car?
