Off-the-road maintenance
Posted: Tue Jul 18, 2006 9:05 pm
So as you may know, my Legacy is off the road for some time. I figure this is a good chance for me to catch up on some basic maintenance.
Here's my list so far:
Oil pump seal
Front crank seal
Waterpump gasket
Thermostat
Thermostat gasket
Spark plugs
Clean IAC
Engine scrubdown
Coolant temp sensor
Here's what I dont need to do (have done in the last 6-12 months)
Coolant system flush
Waterpump (Need to replace gasket though)
Radiator
Rear main
Rear cams
And some other stuff I want to do:
Power steering cooler
AWIC install
Redo all grounding points
Properly mount new scoop
RS foglight instill
Oil pressure gauge
Stuff Im not sure if I should or not:
Front cam
Headgaskets
Any thoughts?
Oil pump seal
Front crank seal
Waterpump gasket
Thermostat
Thermostat gasket
Spark plugs
Clean IAC
Engine scrubdown
Coolant temp sensor
Radiator
Rear main
Rear cams
AWIC install
RS foglight instill
Oil pressure gauge
Front cam
Headgaskets
Any thoughts?
