How To: Poly Rear Droplink Bushings (Pics)
Posted: Wed Jul 19, 2006 5:51 pm
I've got a '90 FWD L, so anyone with the old style rear droplinks (before the cars got those fancy C style links) can use this mod. I just got back from testing them out, and it does seem to help keep the backend tighter in corners. I noticed less tire squeal. I can't say they helped as much as the front endlinks do (I got the whiteline links for the front) but for the price, you can't beat it.
I got some Addco endlink bushings off ebay for like 10 bucks. The Summit website has them for about the same price, so you could get them there too. Any size will work, because all the bushings are the same size. Another nice thing too is the kit provides enough bushings to do 2 cars, or the same car twice incase you screw up
This is the 5" kit I got with the old bushings beside it:
Out of the box, they're a bit too tall, so you have to shave the one end down some. The other end that goes in the cups fits perfectly. I just used my sanding bit for my dremel and got them done in a hurry (you can see the poly dust all over my hands, I was covered in it):
Here's a comparison between the old and new bushing (sorry it's blurry):
To get the old link out, you'll need one 14mm wrench, and a 12mm wrench and 12mm socket. Unbolt the 14mm nut and then the 12mm bolt at the top remove it and take a jack to lift up the swaybay until you can get the endlink out. Replace the bushings the same way you took out the old ones, and tighten all back together. I wasn't sure how tight to make the 14mm nut, because the poly bushing kept compressing and I didn't want to hurt it. I may tighten it some more after a few miles but I don't know how far I should take it.
That's it. The project cost me 10 bucks, and only took 40 minutes. Definately a good cheap improvement. Next I want to fix the rear swaybar end bushings. Hope someone can use this!
