FYI: EJ22T w/ DOHC and Wiseco
Posted: Wed Jul 26, 2006 2:05 am
by napphappy
I finished building the engine and should have it running by the end of the week. I thought I would share some findings.
This may be common knowlwdge but....
The Wiseco pistons K601M975(Stock Replacement .020 over) have a 20cc dish,(7-8cc less than stock) making them perfect for the Phase I DOHC swap. With the Wiseco's and the DOHC it should be around 8.0 to 1 comp.
This is with the stock EJ22t head gasket.
Wiseco(and almost everyone else I talked to) does not recomend running less than .030in piston to head clearance. With the EJ22t head gasket you have about .042in clearance. With the "thin" EJ22 headgasket, you are left with about .015in clearance. Thats about half what Wiseco recomends.
Posted: Wed Jul 26, 2006 3:38 am
by RS25
and what is the piston side clearance to cylinder wall..?
also do you happen to know what the thickness of the oem headgasket is.. cause I've got cometic headgaskets that are .051 thick.. sooo i'm wondering what my clearance would be.
Posted: Wed Jul 26, 2006 6:04 am
by napphappy
I ran .003 side clearance, since Im not running "high" boost. If you are going to be running higher HP levels you should run larger clearances.
The stock EJ22t HG is about .054in. So that Cometic should be fine.
Posted: Wed Jul 26, 2006 8:55 am
by AWD_addict
Where did you get your machine work done on your EJ22t?
How much did it cost and are you happy with their work?
Posted: Wed Jul 26, 2006 5:52 pm
by napphappy
I used a local guy that I like alot. We talked alot about tolerances, bore finish, ect... And I was able to hang around when he bored the block. Which was nice, because I was able to see the final measurements, and they were right on. It cost me $20 a cylinder to have it bored.
Whoever you use, talk to them ALOT, before you decide to use them. Be sure they are willing to work with you.
Posted: Wed Jul 26, 2006 6:00 pm
by bmxpunk
what are you looking for for boost and power? i am trying to figure out my cleances and such as well as what pistons to use. what did yours cost if you dont mind me asking?
Posted: Wed Jul 26, 2006 7:12 pm
by napphappy
I will be running about 15psi and 18psi max. Im guessing around 250-275CHP.
The pistons cost me 455 shipped. Not bad considering they come with rings, pins, and clips.
I think
http://www.importperformanceparts.net/ is about the cheapest.
Posted: Wed Jul 26, 2006 7:17 pm
by Matt Monson
Nice to see this coming together. You are way ahead of me and my Ej22T build. But then I don't even have my SC installed yet...
Posted: Sat Jul 29, 2006 11:32 pm
by Josh Long
That is sweet! We should set up a time once you get it running to check out each others Turbo Outbacks!
I finally got all the wiring chased out and have been driving it to work.
Re: FYI: EJ22T w/ DOHC and Wiseco
Posted: Fri Aug 04, 2006 7:12 am
by 93forestpearl
Sweet. I didn't realise the Wisecos had less dish. Now I'll more apt to get the phase I DOHC heads. You just made my day
Posted: Sat Aug 05, 2006 1:51 am
by napphappy
^Cool
UPDATE: Now Running
More Observations: At .003in piston clearance there is some slight piston slap(knocking noise) at start up. This was worriesome at first, becuase it sounds alot like a very slight rod knock. But the sound goes away in a few minutes, after the pistons warm up a bit.
Posted: Fri Aug 11, 2006 5:58 pm
by 93forestpearl
More updates?
Glad to hear its running. I went with Wiseco's reccommended side clearance. I was expecting a little slap on startup, as I was told that's part of having forged pistons. I'm shure it'll still be a little disconcerting at first.
Posted: Fri Aug 11, 2006 10:07 pm
by Adam West
Love to ride along with you and hear and get a feel for his mod at the upcoming Subaru meet/show. You going to be there with this project?
