Possibly looking for a BROKEN pres. exch. solenoid
With the bigger turbo, the stock solenoid won't work, and I want to do the resistor thing to make the ECU happy.
I'd like to make a plug n play harness, and don't really want to cut up a perfectly good working PES. Anyone have a broken one??
Or possibly know of a similar style connector somewhere else on the car?
MAP sensor reads pressure provided by PES, which switches between manifold pressure and atmospheric pressure.
-Chris
91SS 4EAT stock, 200k mi
I'm sorry....I called it the wrong thing.....it's the wastegate solenoid that I want....not the PES.
The PES & boost sensor will work fine....it's the stock wastegate control that won't really work right, since the the ECU want's to cut boost at 8.7 psi....and the wastegate spring doesn't open until 11 or 13 psi.
Anyway....I was looking at things this weekend, and turns out the wastegate solenoid & tranny resistor have the same plug, so it should be pretty easy to tweak things.
