Keyless entry problem 95 Legacy
Posted: Sat Jul 29, 2006 3:47 pm
by MikeC5
I know it's a 95 but maybe someone can point me in a direction for info on getting the keyless to work. The P.O. bought a new key fob after losing the original but couldn't get it to work. I tried replacing the battery, no luck. Any clues?
Posted: Sun Jul 30, 2006 12:14 am
by Josh Long
Find the keyless entry box under the dash if it has one. ( it will be needed for this) and depress the black button that hangs from it's wiring loom, while depressing the lock button on the fob. Your doors should now lock and or unlock.
Good luck
Posted: Mon Jul 31, 2006 2:40 am
by MikeC5
Thanks Josh. Might you have any idea which side or any other clues to the specific location?
Posted: Mon Jul 31, 2006 2:53 am
by Manarius
Umm, on the 95 I think it's under the glove box or thereabouts.
Posted: Tue Aug 01, 2006 2:38 am
by MikeC5
Thanks!
Posted: Wed Aug 02, 2006 4:05 pm
by smidge
hey guys having a similar problem on my 96 legacy.....
i've pulled the keyless box out of the dash but haven't found any button to press on the loom ???
occasionally if i point the key fob really close to the infrared sensor the locks will snap locked and then snap unlock again.... but then won't work for a while afterwards....
the central locking works fine with the key however...
anyone have any ideas? this has been driving me nuts!!
cheers
