Retrofitting 92-94 Waterpump
Splinter
Post by Splinter »
Rather than buy a new pump, I retrofitted mine to work with the stock oil cooler:
Pretty easy. Drilled it out, tapped it, put in a fitting.
The only thing Im notsure about is how I should go about sealing it. Regular water-gasket stuff?
thehookeup
Re: Retrofitting 92-94 Waterpump
Post by thehookeup »
The only thing Im notsure about is how I should go about sealing it. Regular water-gasket stuff?[/quote]
that would be my guess, or you can try teflon tape.
but it looks good and cheap i like it
-93 2.2T (RIP), 93 N/A best car on earth.
-00 legGT, 18" PIAA sport mesh wheels, front/rear Rallitek sways, lowered whitelines, coming soon: 2.5L sti internals, 20g heads P&P, twin charged. motor is almost ready to go in.
Andrew
