Front Swaybar Mount Bushing Options?
Posted: Tue Aug 22, 2006 3:40 am
My front bar is desperately in need of new mount bushings, the old ones are just destroyed. I had my car in the ditch and bent the control arm, I'm amazed that the bar itself didn't break, but no worries.
I've already got the whiteline front endlinks and I was wondering what I could do for new bushings.
I've done some searching and there seems to be some debate if the bar is 18 or 19 mm. Does that make that much of a difference? I was looking online at some bushings, and cross referenced some impreza bushings with the legacy, and then others had different part numbers and listed a bar size of 19mm.
I was also looking at some energy suspension universal PU bushings and they came in both 18 and 19mm sizes.
Will the stiffer PU make a difference if I used them, or should I not care and just get whatever Napa has?
