Page 1 of 2
The passed-around standalone
Posted: Tue Sep 12, 2006 5:59 am
by Splinter
With the destruction of my engine, Ive got no current use for it.
I think it was originally Legacy294's. He couldnt use it because he has an auto. Then it was DZX's. He couldnt use it because of time restrictions on his daily driver. NOw its mine. Should it be yours next?
Once again, it's a Redline-Weber 882C which has been rebadged by Perfection Motorsports. It comes with a plugin harness for the 91-94 TUrbo Legacy and a base map. ALso comes with the crank sprocket and intake charge temp sensor. Software with license is also included.
Asking $1000 + shipping. I never installed it.
Posted: Fri Sep 15, 2006 6:35 pm
by Splinter
bump
Posted: Tue Sep 26, 2006 11:46 pm
by Splinter
Wideband O2 sensor included for $1100
Posted: Fri Sep 29, 2006 4:01 pm
by greg donovan
that is really cool.
i wish i had a reason (and the cash) to buy it.
Posted: Mon Oct 16, 2006 7:54 pm
by Splinter
Bump
Posted: Mon Oct 16, 2006 8:34 pm
by ShaggyGT
Why can this not be used on an AUTO? My Leggy Turbo is an Auto of course......
Posted: Mon Oct 16, 2006 10:54 pm
by Splinter
ShaggyGT wrote:Why can this not be used on an AUTO? My Leggy Turbo is an Auto of course......
Do a 5MT swap.
Posted: Mon Oct 16, 2006 11:27 pm
by ShaggyGT
If it were that easy. I have a tranny here that would work but the cost for the rest of the conversion would not be worth it at this moment.
So whats the reason why one cant use this standalone with an auto????
Posted: Mon Oct 16, 2006 11:33 pm
by Splinter
Doesnt give the proper feedback to the TCU
Posted: Tue Oct 17, 2006 6:09 pm
The only thing the TCU needs from the ECU is engine RPM. The other info the TCU gets directly from the sensors. So unless you have to swap out a lot of sensors, you could probably rig something up with the engine rpm input.
Posted: Tue Oct 24, 2006 5:23 pm
by VRoman
Will it work on 94 NA Legacy? Is actually worth buying for a EJ22 engine? I plan to get new cams and heads some time this winter.
Posted: Tue Oct 24, 2006 6:03 pm
by Splinter
This is the same one DZX was selling
I dont see any reason why it wouldnt work on an NA, although the fueling would have to be played with, and 2 or 3 wires changed
Engine management will always help you get more out of your engine.
Posted: Sun Dec 03, 2006 10:36 pm
by Splinter
Ok Ill willing to take a hit on this...
$800.
Thats quite a bit less than I paid for it, and I never even installed it. I just want it gone, Ive got an Autronic now.
Posted: Sun May 13, 2007 11:00 pm
by TheDaveler
Still got the ECU? If so, what kind of features does it have? Built in boost controllers/turbo timers any fancy stuff? How flexible is the software (Limitless?)
Posted: Mon May 14, 2007 12:39 am
by Splinter
You can use it to control the stock boost solenoid, Im fairly sure it has anti-lag support, I dont understand what you mean by how flexible it is...
Posted: Mon May 14, 2007 6:37 am
by georryan
DANNGGGGG, if only I wasn't tied up in moving right now....
Is this Perfection Motorsport's standalone ecu they had been developing? If so, this is a steal of a deal.
Posted: Mon May 14, 2007 7:04 am
by Splinter
Yep, this is the one...
Posted: Mon May 14, 2007 7:05 am
by TheDaveler
Since it uses the stock connectors, i was wondering a few things about the potential of the unit in how far i can go with performance mods.
Posted: Mon May 14, 2007 7:31 am
by Splinter
Couldnt really tell you, Ive never used it... Id imagine pretty far, it gives you total control over timing, fueling, etc
Posted: Tue May 15, 2007 7:14 pm
by TheDaveler
Somewhere closer to july, I will be able to buy that from you, im sorry it cant be sooner.
Posted: Thu May 17, 2007 3:37 am
by Splinter
I cant hold it for you, but its been for sale since september so I dont think its going anywhere
Posted: Thu Jul 30, 2009 4:19 am
by Splinter
I still have this... Trying to clear out my basement now.
$400 shipped, as is.
Posted: Thu Jul 30, 2009 4:07 pm
by n2x4
sent a PM
Posted: Sun Aug 02, 2009 11:00 pm
by yazmo
that bad its not working on automatic
Posted: Sun Aug 16, 2009 8:57 pm
by Splinter
$350 USD shipped
It comes with a wideband oxygen sensor, btw.
