Cam and Crank Sensor
Posted: Wed Sep 13, 2006 4:51 am
I'm in Desperate Need of Cam and Crank Sensors for my 91 Legacy EJ22. I was having trouble with it overheating and after replacing EVERYTHING else I did the HG's. Car was starting and running fine before HG saga. Well after putting it together and taking it back apart for the usual ( oops I didn't get the Timing right mistake) I can't get any spark. Today I messed around with the crank sensor and pulled it out put it back in and got it to spark a little bit but after messing with it for an hour i couldn't get it to spark anymore at all...So I think that must be my problem. Also when i was putting the Intake back on I had alot of Dryrot on my cam sensor wiring and about a 4 inch section has cracked off so I covered it with some black tape and am hoping that will hold.... So If anyone has either or both of these please name your price preferrably well under what Advance Auto thinks is a fair price of 468.00for one and 278.00 for other.
