IAC location?
Posted: Wed Sep 20, 2006 2:34 am
by BSOD2600
I just got a 94 touring wagon last night, so I'm unfamiliar where all the various component locations are. When the car is cold, it idles high. While in neutral, if I press on the throttle the car almost dies or does. I'm thinking the IAC is gummed up or needs to be replaced. I've read around online that the IAC is, "incorporated into the throttle body".
Does anyone have a real picture where the heck this is? I'm sure I keep looking it over and not realizing it.
Posted: Wed Sep 20, 2006 7:06 am
by BSOD2600
Here, I took a pic of my stock engine... circle it for me.
I'm thinking it's the circular white thing, which is partially visable in the last picture -- 'bout 7 o'clock from the coil pack?
Posted: Wed Sep 20, 2006 3:26 pm
by Saskatoon Subaru
i have been woundering the same question
Posted: Wed Sep 20, 2006 5:21 pm
by n2x4
It's under that black hose. 4 bolts hold it on to the side of the intake I believe. Have you checked the codes? It could be the IAC, or maybe the throttle sensor. Just a guess. I'd check codes first.
Posted: Wed Sep 20, 2006 8:26 pm
by BSOD2600
Nope, haven't checked the codes -- the check engine light hasn't been on. Will Schucks ODB reader work for my car?
I'll take that hose off tonight along with the IAC and clean it, hopefully that fixes my idling problems.
Posted: Wed Sep 20, 2006 9:52 pm
by n2x4
Posted: Thu Sep 21, 2006 1:46 am
by IronMonkeyL255
Wow..... It's kinda odd to think my engine compartment used to look like that before I started modding the hell out of it.......
Posted: Sat Sep 23, 2006 1:14 pm
by Bane
lol Monkey, i was thinking the same thing... look how much room there is!
BSOD, engine looks really clean... hows the body holding up?
have you checked the air filter?
Posted: Mon Sep 25, 2006 6:31 pm
by BSOD2600
Bane wrote:BSOD, engine looks really clean... hows the body holding up?
The body is in really good condition (from what I've seen and been told by other Subaru people).
I briefly looked at the air filter the other day and it seemed a little dirty. Was planning on replacing it with a K&N soon, along with removing the snorkle box thingy in the fender and running a pipe from the fog light to the airbox.
Actually, after driving 500 miles on it now (to college), the car didn't have an idle problem this morning.
