Whats goes in this hole in my dash?
Posted: Wed Sep 27, 2006 1:35 am
by BSOD2600
I was trying to figure out what alarm came with with my car so I took off the lower part of the dash. Noticed the panel below is empty. What feature/device is suppose to go in there?
Posted: Wed Sep 27, 2006 1:46 am
by entirelyturbo
A coin tray.
Posted: Wed Sep 27, 2006 2:26 am
by free5ty1e
My 91 has the coin tray, marked Tray and with an easy-open handle.
My 92 and 94 both have the plain plastic panel there, it can be popped off pretty easily by hand.. and makes a pretty inconspicuous hiding place.
Posted: Wed Sep 27, 2006 8:53 pm
by alcyone
They never made the coin trays for the black interior, only a plastic cover. You can, though, get a coin tray from a junk yard in any color and paint it with "BBQ Black" spray paint from walmart. I've found it's a perfect color match for the black interior.
Mike
Posted: Wed Sep 27, 2006 9:21 pm
by free5ty1e
I also found it was a good place to extend the check connectors into... to flash engine codes all I have to do is pop the cover and connect 'em up, instead of having to remove that piece. I lengthened the wires enough so that the panel can be dropped to the floor safely.
Of course, I've since installed a parallel connector and power for my car laptop to run Vikash's select monitor software, so I haven't needed to flash any engine codes...
I didn't realize it was an interior color thing and not a model year thing, that's strange.
Posted: Wed Sep 27, 2006 11:04 pm
by skid542
To answer the original question.
On 92-94's I do believe that is where there is a bit of ABS stuff. Not a coin tray. Or atleast my blue interiored 93' L (with no ABS) didn't have a coin tray and just had the cover. Somewhere around on it there is something stamped ABS if I recall correctly.
Posted: Wed Sep 27, 2006 11:35 pm
by Richard
My 93 and 94 both had blank covers in that spot. I don't anything with the ABS goes in there.
And yes it is a great hiding spot. With a little dynamat or rubber coating inside, nobody would know the difference.
Posted: Thu Sep 28, 2006 12:38 am
by skid542
Flip the large panel over, not the cover, but the underdash panel and what's it say on the back of it?
Posted: Fri Sep 29, 2006 4:13 am
by alcyone
skid542 wrote:To answer the original question.
It's stamped "ABS" because it's made out of ABS plastic. :-)
Posted: Fri Sep 29, 2006 6:16 am
by skid542
^^^ ahh.... :roll:
Posted: Fri Sep 29, 2006 7:13 am
by entirelyturbo
Yeah, I should have clarified that the 92-94's only have a block-off plate there.
The ABS models have the control module right under the stereo, ahead of the shifter. It sticks out of the dash, unlike the non-ABS models that have a recess in that area.
Posted: Mon Oct 02, 2006 11:38 pm
by thefultonhow
subyluvr2212 wrote:The ABS models have the control module right under the stereo, ahead of the shifter. It sticks out of the dash, unlike the non-ABS models that have a recess in that area.
I thought that was the airbag control module?
Posted: Tue Oct 03, 2006 4:41 am
by Bheinen74
yes, the thing under the stereo, in front of the shifter is the SRS air bag module.
ABS = antilock braking system
SRS = supplemental restraint system (ie...air bags)
Posted: Thu Oct 05, 2006 4:17 pm
by IronMonkeyL255
ABS control module is located under the front passenger seat.
