What size Optima battery under the hood of a stock SS?
Posted: Wed Oct 11, 2006 6:38 pm
Well, after sitting all summer, the battery in my SS is SHOT, so I'm going to replace it with an Optima unit. I did a search, and found a lot of you guys went with a slightly bigger battery than stock, but stashed it in the trunk.
I'll most likely be keeping mine under the hood for now - what will fit? I think it's a "Group 35", but I just wanted to be sure (especially becuase the only place I can find a Group 35 Yellow is at Summitracing.com, and it ends up being $10 more than a Group 34 at sears due to handling charges).
Also, if it IS a group 34, which one? There's a D34/78 and a regular D34. (I think the only difference is that the D34/78 has side posts as well as top posts).
Look here for Sears:
http://www.sears.com/sr/javasr/subcat.d ... ord=Optima
Here for Summit:
http://store.summitracing.com/egnsearch ... 6&D=306986
Thanks guys!
Here for Summit:
Thanks guys!
