Finally got my setup installed and finalized last week, and so far I freakin' love it.
So the setup is basically like the title says, Inverted struts on all 4 corners with Ground Control hardware and Ground Control provided Spec springs from Eibach.
Everything else on the suspension is stock.
My rates are as follows:
Front 425lb/in
Rear 450lb/in
Everything else is stock. Its a little rough to ride in downtown, but its freakin awesome on the curve-laiden roads on my way to and from school/home/work
The car is lowered around 1.5" and there isnt one bit of tire scraping, even with 225/45/16 tires. I love this setup, will probably love it more when I install my Eibach tender springs in the front!
STI inverted struts + Ground Control
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
1988 4Runner RIP
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
